Andamo
I ran into a problem yesterday while installing a garage vacuum. I had to run wire (14-2) from a end of run box over the garage door and install a plug for the vacuum. I just wanted to check the live box, and when I did, it arced against the side. My power for these wall boxes comes out of the main panel in the garage and then goes through a GFCI so that all the wall plugs are protected by the one GFCI. I reset the GFCI after the arc in the box and finished up the plug for the vacuum. After I was done I flipped on the breaker and I thought all was good. But later I noticed that the upstairs lights along with the wall plugs and outside lights were off. I got to looking and checking and I now only have 110v coming into the main panel on the one wire. The other wire is dead. These 2 wires come from the house underground and go into the garage panel into a 100 amp breaker.
A few years ago I had to have one of these 2 lines dug up and spliced since I hit one of them with the rototiller blades. Everything was working fine before the problem in the small work box and I find it odd one leg is now dead.
What should I be checking at this point ? I moved wires around so that I have outside lighting, door openers, lighting downstairs and heat.
