ok, i took everything apart except for the pump part and the valves. The cylinder and piston and cylinder housing, i dont see any cracks, all the o-rings fit nice and tight, BUT there is alot of metal shavings in my jack oil, i mean ALOT. I also had two metal screens fall about when i pour the oil out of the cylinder. Where should i go now hi ball?:-/
Well you need to find out where the metal shavings are coming from, The metal screens sit inside the pickup in the resevoir. If there are that many metal shavings it should be easy to find the cause. Your also gonna have to get into the valves account the shavings.
