lamboworld
- Joined
- Dec 20, 2013
- Messages
- 6
My new compressor should be in next week and I am trying to get my wiring options together. I have posted some pics to give you an idea about what I am thinking.
My first option is to install the compressor in the small closet in my garage. The closet currently has a tankless hot water heater installed in the closet with a 30amp disconnect that is wired with 10 gauge wire. Is there anyway that I can use this connection to wire in my compressor. The hot water heater is used to heat the water in an apartment that is located over my garage. No one lives in the garage and it would be very unlikely that I would ever use both at the same time.
The 2nd option is to use an existing 240 outlet with a 50am breaker. I assume that I will need to just change the breaker to a 30amp and install a disconnect where the outlet is if I want to hard wire it rather than using a plug.
There is really no way to run additional wire into the closet so I can only use this option if I can use the existing connection in some way.
Thanks for any advice that you can give me.
https://plus.google.com/photos/106928552337874988572/albums/5962579206656560225?authkey=COHbyKmBv6SymgE
