newpain01
I installed a mini split in my garage last year and it worked fine for 6+ months and then stopped. When I turn it on, the fan kicks on but not the compressor. I suspected that the refrigerant leaked out, so hooked up some gauges and it's shows 0 psi, guess that's why the compressor doesn't turn on. It's should have 17oz of that eco gas, R32.
Called a couple HVAC guys and they do not want to work on DIY mini splits. The other day I found a guy who said he can refill it after I fix the leak, but other than that he doesn't want to work on it to find the leak or do a pressure test.
I know they use nitrogen for pressure testing, but I don't have any and don't really want to spend $200+ to get a tank just for this one time use.
I do have a lot of CO2 and two tanks of pure argon for welding, so I am wondering if I can use those for the pressure test. I heard CO2 is not recommended because it might have moisture but I want to hear opinions if anyone used argon or CO2.
If so, what kind of adapter do I need to connect the regulator to the HVAC gauges (yellow hose) and what pressure do I need for the test? He told me if I am using nitrogen to get it to 300psi and listen for hissing.
Any help appreciated!
