Good evening.
I was looking at my air handler in the attick. I looked up online and it had a door for filter. Since my filter comes earlier in the intake (Intake is in the house with the filter right at the intake door level), I never thought much about this one. I guess I got a bug today to check if there is a filter there (system installed long time ago - did not remember)
The filter access panel (probably around an inch wide and going top to bottom of the air handler) was covered in Foil Grip 1402 tape. The adhesive tape was really tight on - ripped off small pieces at a time and then I just ripped tape on both sides of the access panel so I cold slightly move it... (probably first 5 inches to just move the top and flash some light inside and see if there is a filter.... there was none...)
Well, I do not have any similar tape at home.
So, 2 questions:
1. I covered the top with aluminum Flex Fix tape for Class 1 ducts ( tape has a sign UL181B-FX 64YF) - I think it should be sufficient - is that correct?
2. Is there any benefit of trying to get the original Foil Grip 1402 tape to cover that to part of Filter access door?
3. Do HVAC professionals usually carry that tape? (I will need to have the air handler serviced and cleaned at some point. I doubt they would want to take off the old tape, but might put a small strip to just cover the area I uncovered...)
Thank you
P.S. Trying to figure out what to do with it - I have no other use for the tape and buying a big roll will be just wasteful if not needed...
So, 2 questions:
Thank you
