question on dies
Buckgnarly
VT
I have some like that, older "Ace" used to use the die shape too. I think you can still get the handle from SO.
The set screw is to adjust the threads for a tighter or looser fit.
A_Pmech
IL
That is an adjustable die. It allows somewhat crude adjustment of pitch diameter.
woody 73
The Great State Up North
For some reason I am still a little confused op is there any chance you could show us a picture of the die in question. I don't recall seeing a twelve point die, not saying they are out there to be seen just that I do not recall seeing one; I have seen square, round, & hex dies.
G
gungatim
west mich
i'll try to grab a pic tonight when I get home. I'm not sure if it's 12 or 8pt. but it's definitely not 6pt...
Buckgnarly
VT
Aqua-Andy
I have a full set of standard and metric Snap-On dies that are 12 pointed. These are actual cutting dies not chasers.
rsanter
visalia ca
Those are very standard. You can use a 12 point socket or wrench on them as well as the handle for them.
Yes they are adjustable, but they are adjusted to a standard setting. Threads have classes of fits, this enables the manufacturer to adjust the die to a more precise standard class of fit but it also allows a really knowledgable user to adjust then for a tighter or looser class of fit if need be.
If you don't know what I am talking about, you should not adjust them
Bob
Robby321
Olympia, WA
Beg to differ. All my cutting dies are round, meant to be put in 2 sided handle for doing straight (think perpendicular to the bare metal) threads. Sure, you can use a 6/12 point die, but not made for that.
G
gungatim
west mich
heres a couple pics. sorry for the low quality...got a new phone on order.
the one shown is 10mm
also curious on why some have 3 clearance holes, some 4, some 5, some 6. I get the 3 for smaller ones but larger ones don't seem to follow a specific pattern...
Buckgnarly
VT
My older US made Cman set is all 6 point, I also have those two SO sets (metric is Blue Point), they are for cutting and NOT chasing.:thumbup:
Are you saying ONLY round dies are for cutting?:confused:
bwringer
Indianapolis
Pardon me, the others seem to have missed their duty to issue a hearty "YOU ****!!!!"
I mean, $5 for all that?
G
gungatim
west mich
actually $5 was for the craftsman toolbox, (with those dies) a piston ring compressor, piston ring expander, piston groove cleaner, K-D 2400 OHV valve spring compressor, about 24 taps, 3 tap handles, one die handle, craftsman robogrip pliers, 3 sets of crimping pliers, a few xcelite nut driver bits, and I forget what else...
oh yes I do, a brand new in the box, still sealed in plastic, Craftsman 1-3" micrometer...
I just don't usually show off all the yard sale stuff I get deals on...I hit about 30 sales a week during the summer and only stop when the vehicle is full. I really need to start re-selling some of this stuff.....
2oolhound
BC Canada
Agree ^^^
They are cutting dies. At one end they cut 75% nominal (standard for basic dies) and at the other end they cut 60% for a looser fit. Other split dies can be opened up too but it is more difficult to gage what you are doing.
and yes, you ****!
Finky198
North East
I have both 41 pc std and metric sets of snap on (irwin) 12pt dies and taps...
they are def made for cutting new thread or chasing old ones the nice thing about the adjustment is you have more control over your final tolerance, as well it can make them much easier to start with less tolerance and you then set the desired final size...
The handles that come with the set are made for 12pt dies.... and from what I have heard from the Snap on reps is that it just gives the mechanic more use ability with all the different drive tools and combinations you can make to reach in place you could never get to with a round die..... I used this feature a few times with great success...
here is a chart showing thread tolerance's
