Question on hardwood flooring.
ive
Canada
Hi all.
I truly appreciate being able to come here and get answers to many things. Thank you!
My wife wants hardwood flooring. I'm wondering if there's such a thing as being able to remove a piece if it gets damaged. I thought I remember a guy telling me that once upon a time. Am I crazy?
Thanks so much!
kamlung
North NJ/NYC, USA
Yes if it gets damaged even though the hardwood is tongue and groove, you cut out the damaged piece and glue in the replacement.
kd3pc
Northern Neck
be sure to save some of the flooring you plan to use, just for this reason. It is better to work with some of the same flooring than using a generic piece, or having to custom cut, stain and such.
Good hardwood is tough to really damage with normal day to day usage.
BJ42LX
WNY
Yes, this.
Getting it out involves some finesse with saws, chisels and pry bars. You have to be very careful to get the one board and nails out without damaging adjacent boards.
Fitting the new one will also involve some wood work.
At the same time, you have to do some real damage to warrant cutting out boards. Scratches - even deep ones - can be repaired by sanding, swelling the wood and refinishing.
rlitman
Long Island
My hardwood floors have been there since 1949 and have survived, fire, flood, dogs, cats, children and me.
1929 here. Fire did destroy one room's floor, never had a true flood, but have had plenty of water drip from bathrooms on the floor above. Many children have been through this house before I owned it, and two are in it now. The hardwood looks great.
As for removing the one bad board without damaging the surrounding boards. There are many ways to accomplish this, but a Fein tool makes short work of it.
Yes, you can replace a single board, or a section. But getting it to match perfectly may be difficult unless the wood already has a lot of natural variation (not really seen in today's flooring), or you have extra pieces. Same thing goes for any stain you use. Put the can away somewhere.
But it takes something really bad to damage a hardwood floor board to the point that it needs replacing. In all honesty, every hardwood floor board that I've seen replaced was done when someone bought a house, ripped up the carpeting that covered the hardwood, went to refinish the hardwood and wanted to remove the stains where a pet had peed in some corner of the carpet and soaked the flooring beneath. OR, when huge cast iron steam radiators were removed to replace with hot water heat, and large holes had to be fixed (but that's usually solved with plugs and filler).
Never actually seen a board needing replacement from physical damage.
I
ive
Canada
Thanks so much for the input. You gentleman have put my mind at ease.
Thanks again.
James-W
Southeastern Wisconsin
We have hardwood floors and we love them. With the new floor finishes they have today, the floors are practically indestructible. The floor finishes smell really terrible and you may have to leave the house for a couple days after you put down the finish. But once the smell goes away the floors will stay looking great for several years before you need to do it again. If memory serves me correctly, it has been almost 20 years since we had the floors refinished and they still look good.
