Quick NEC question
Mike007
I need to run a 15amp 240v circuit to power a thru-the-wall AC unit in my garage. I'm considering using 2 conductor #14 romex and remarking the white conductor because I have it on hand. I seem to recall a conductor smaller then #6 cannot be remarked as per the NEC. Is this correct? Thanks.
Charles (in GA)
50 mi south of Atlanta
I think you are thinking of 200.6 but that only applies to "insulated, grounded conductors" (ie. neutral) You can take a white wire in Romex and remark it as a hot wire, its done all the time. You are not allowed to take a black or red and remark it as a grounded conductor (neutral). You cannot take a loose wire in conduit and remark the ends of it, in conduit it has to be marked full length. Romex is different.
Charles
VHF
NW Wisconsin
Individual wires that size cannot be remarked, but I belive it is OK to remark conductors in a manufactured cable assembly such as Romex. For example, 10-2 Romex is frequently used to supply an electric water heater with the white wire remarked as red.
mrb
the rule for #6 and smaller is for remarking black to white, and that doesnt apply to cable just individual conductors. Youre fine with your 14/2 as long as the AC unit doesnt need a neutral for some reason.
