Ideally, you probably need a 3/8 drive and a 1/2 drive and it would be best to top out at about 150 ft/lbs on the 1/2 drive.
I work for an airline, we have hundreds of torque wrenches of all sizes, types and brands. on a couple of ocassions I have spent considerable amounts of time with the guy who calibrates all of those tools. I brought mine from home for him to check and we spend alot of time discussing different ones, advantages, best brands, problems, techniques of use, etc.
We have some Snap-On dial type (fairly old), many Proto clickers of mid 1990's vintage, and the newer clickers are Sturtevant-Richmont. The guy doing the calibrating liked the SR tools the most, he said they were consistent in accuracy and even non-linear errors could be corrected. Protos were difficult to adjust if out of range, too far out and you have to change a small rocking block inside the tool, for one of different dimensions, to bring it back in range. Dial types are quite accurate, but if you ever exceed the max torque, just throw them away, there is no calibration adjustment to fix them.
Clickers are generally the LEAST accurate, at 4% to 6% error, while beam type are generally about 2% error (even my cheap Craftsman's are guaranteed to be accurate to 2% out of the box) and the most accurate are electronic one like the SR Exacta Digital series, good to 1% or less.
I got lucky on Ebay and bought some good torque wrenches and acquired others also. I have two Snap-On dial type, one is a 3/4 drive goes 0 to 600 ft lbs, the other is a 1/2 drive and goes 0 to 250 ft/lbs (Ebay, $75 for the pair); a Sturtevant-Richmont clicker made for interchangeable heads, with a 1/2 dr, 150-750 in/lb (Ebay, $26); a Seekonk Mfg clicker, 1/4 drive, 30-150 in/lb and four beam type Craftsmans. Two are about 30+ years old, the other two are about 13 years old. 2ea 3/8 dirve, one is 0-50 ft/lbs and the other is 0-600 in lbs (same difference) and two 1/2 drive, 0-150 ft/lb.
For your reference........
http://www.srtorque.com/
http://www.seekonk.com/
http://buy1.snapon.com/catalog/cata..._ID=121827&Cat_NAME=Torque&store=snapon-store
http://www.sears.com/sr/javasr/sear...cat=Torque+Wrenches&displayTarget=Subcategory
Charles
