Racedeck install problem
ryan141
Hi Guys,
I am having trouble installing my racedeck floor. Most of the install has gone smoothly and I'm down to the final 6 rows and i can't get the tiles to fit together.
I am trying to attach a row of diamond tiles to the free flow tiles and they won't line up. This started to occur about halfway through the row. Ive tried switching out some of the tiles as well as warming them up and nothing is working. If i snap into the free flow i can't snap into the adjacent diamond. The gap gets wider as you move further away from the snapped edge. Any help would be appreciated.
Shea
California
Can you show a picture of most of the floor? How and where did you start with the installation?
CJDave
Fairfield, Ohio
If you detach the diamond tiles from the Free Flow does the gap on the Free flow tiles close up? Then if you join the two diamond tiles to themselves and nothing else is the joint between the diamond tiles tight? From that picture the diamond tiles seem to gapped apart and forcing the FreeFlow tiles apart. Maybe a defect in the loops/tabs on the bottom of the diamond tiles. Flip them over and compare the attaching points on the FreeFlows to the diamond tiles. Dave R.
R
ryan141
Thanks to the guys who reached out to help. Jorgen from Racedeck reached out direct, and i was able to get it fixed. It turns out that the floor wasn't exactly square. I ended up dissembling it in large sections and squaring up each section and putting it back together. I have it mostly done and just have to make the cuts to finish it. I'll post pictures when its done, its looking great so far though. Thanks Again.
Shea
California
Glad you got is solved. Jorgen and his staff at RaceDeck have excellent customer service.
