Radiant Process Heater
Brad1234
I have been looking for quite some time for a heater to heat a 350 sq ft room in my garage. My specifications are something that is inexpensive & does not have a blower. Well I found something that may fit the bill but I'm not sure exactly what it is. What is a Radiant Process Heater? This one is 30" long, 2200 watts, & runs on 110v. Is there any reason that I could'nt use 2 of these to heat a room?
Brad1234
Okay, I received the 120V / 2200W heaters but I am not sure how to wire them. These are not dual voltage heaters so I am assuming that the heaters themselves are wired correctly. They each have 2 heating elements. The elements have a wire connecting them on each end. From each end a wire runs out of the heater which is where I am supposed to make my connections. The wire on both ends is white. I would have thought that it would be black. Seems odd to me to run the neutral through the heater elements. This application will be in my garage so I am using Romex 12-2 w/g.
