Radiant Tube Heater Location Help
olds70supreme
Hello,
After waiting and watching a long time I finally found a good deal on a radiant tube style heater (hangs from ceiling). Now I have three questions:
1. I have heard complaints that they can be too hot if you are too close, but I also don't want it to be too far away (if that is possible, given that they are line of sight heaters). Below is a sketch of my garage where I work on my two old cars and do limited woodworking. Any suggestions on which (A, B, or C) would be best, or any additional locations? If absolutely need be I can move the overhead shelving.
2. I plan on tying into the existing house gas line and running flexible copper line up the garage/house wall, above the ceiling (in the attic) and to the heater. Are there any issues I might run into with this? Would it be better to go with black iron pipe on the inside of the garage (leaving it exposed)?
3. I would like to vent the heater out the back wall of the third stall (right/west side). I believe I need "B" vent to do this, correct? Also, does the vent pipe stick out of the wall horizontally or does it need an elbow outside to turn it vertical?
Thanks.
Dragster Racer
Morrison, IL
I believe you can run horizontially with the power vent.
I like the location by the doors angled, but realize that the door area will be pretty chilly. You could consider a u tube to cover more of the area that you work in. Put the thermostat where you will work, but out of direct line of the radient heat, and I think you will be comfortable. I have looked at these heaters, but just haven't pulled the trigger. Oh, black pipe is what I ran inside.
