Ran across problem by accident.
428PI
Peabody, KS
I was installing a new 14=50 outlet in my shop and was just pushing in the breaker and I heard a sizzle. I know I didn't have a short. Found aluminum feed wire on one leg lose. I moved wire just enough when 6 gauge wire from breaker pushed on it slightly. I removed wire and put some anti corrosion paste on it and reinstalled it. No signs of overheating. Square D box. Same thing happened in my CH box in house 20 years ago. Burnt one inch of insulation on that wire at that time.
solo machinist
North West, Ohio
My ex sister in law bought a house built back when everyone was using aluminum wire.
I checked the panel box and all the wire were loose. Everything looked fine other wise.
mike93lx
Richmond, VA
Really should cut back the wire to fresh aluminum and reinstall, but I wouldnt be surprised if the slack isn't there to do it
428PI
Peabody, KS
That's what I did on my house. I was able to cut off perhaps 1 inch and that's it. I did replace the breaker it fastened to also. On my shop I think I just caught it. I've been charging up my EV at 16 amps for an hour and the temp a couple inches above the bus bar where it attaches is still at 60 degrees. I upped the charging to 32 amps (max charging cable and car) and will check it in a couple hours.
