Random mechanic tools identification???
Kracin
Omaha, NE
Ole Slewfoot
Freedom, CA
In the mass pic, the red thing is a tailpipe expander, the center bolt always dies,at least with the harbor freight ones.
the yellow handle tool is for turning the little discs that hold a drum brake to the backing plate.
Proto and Exelite use that color, but so does China.
areyouanywhere
Re: ITEM #17= Pile of ??????
Evidently I got sick of taking pics of every single item.... maybe I'll try harder with it tomorrow.
The hoses look like GM and Ford schrader valve adapters for testing fuel pressure.
Lower left (in 1st pic) segmented thing is part of a exhaust pipe stretcher, missing the center bolt and nut.
Slide hammer/ blind hole puller
A/C low and high side fittings are the red and blue valves
Those blades look like they go on a pneumatic gasket scraper
GM door spring tool is the silver thing on the right of the 1st pic.
Tony G
NewHampshire
Item 12 post 23 is a set of clips to prevent the rocker arms from shooting oil everywhere when setting hydraulic lifter adjustment.Mostly used on Chevy cast iron v8.
mcmtech
New Orleans, La
Pic 17 pile, first pic. Orange thing is a gauge for serpentine belts. On the far right big silver tool looks like a spring compressor for springs in Chevy truck door hinges.
joecon
#9 cv axle puller goes between the axle and the trans
#10 fuel line clamps for checking fuel injection
#11 wrench to hold cam sprockets to change the seals
bcschief
Crescent City Florida
Item #17 little orange thing is a serpentine belt wear gauge most likely from gates belts. The piece with the U shaped cutout in the end is a clutch line release tool for a Ford Ranger Aerostar and F model pickups. The scissor looking thing is a brake lining measuring tool
c39er
Seattle, Washington
Post #12 is part of a Posi-Lok puller. A very good company that makes great pullers with a adjustable tightening cage around the 2 or 3 jaws.
^ I believe you are correct. looks like it's missing the cage and the t-handle.
I have a #104 - one of the best tool investments I ever made.
