Re-Using Basketball flooring
ArtisanFarms
Phelps, NY
A local building recycler has a lot of used basketball flooring from an old school.
Has anyone laid this over concrete? I'm looking at some as potential flooring in my wood shop and also in part of the basement.
rsanter
visalia ca
Define used?
Dialed down and pulled Up?
Glued down and pulled up?
Segementee flooring that floats and cam be locked together (like the stuff they use in convention centers)
Depending on if it is cheap enough, the condition, the type it is....it could be a great deal or a big PITa
A
ArtisanFarms
Phelps, NY
Define used?
It came out of a school that was being taken down and is segmented. I didn't check to see if it was camlock, but it is a maple deck on a frame. The sections look to be about 1 1/2" thick.
txvwnut
Bedford, Texas
If it’s the same maple they use in bowling alleys that stuffs hard as hell and hard on blades when trying cut it.
duneslider
Riverton, Utah
If it is segmented it is probably fine to go over concrete as that is how it was installed at the school. If this is in a basement then you still need to make sure potential moisture is addressed.
