Above 1200 Sq/FT Rebuilt after a small gas leak
J
Jo Diesel
St. Johns MI
The exhaust flange broke off at the turbo so I had to fix that and replace rest of exhaust. It used to dump under cab
J
Jo Diesel
St. Johns MI
Went to replace batteries and the tray was junk so I made a new one
J
Jo Diesel
St. Johns MI
Installed light over toilet and replaced rest of lights with LEDS
J
Jo Diesel
St. Johns MI
Installed holding tank. mark and drill holes. Remove tank. install grommets. Reinstall tank and complete plumbing and run vent through roof
J
Jo Diesel
St. Johns MI
I have a pair of grey leather seats our of a Suburban. I am going to see if I can adapt them to the seat bases in truck
J
Jo Diesel
St. Johns MI
Finally got around to building a work bench. started a new job and wanted my own table
matt_i
Good looking weld bench, does it use T-bolts to trap in between the channels or are those more for C- or bar clamps?
J
Jo Diesel
St. Johns MI
I can use the T bolts that I use on my mill and Welding clamps will slide right in the slots also. I plan on welding a plate to a welding clamp that I can bolt on also.
J
Jo Diesel
St. Johns MI
Started another project. Not in the shop
J
Jo Diesel
St. Johns MI
Have been wanting a sunroom since we built the house first beam went up with a pulley and rope to the skidsteer. This was me and my wife. Got really sketchy but we got it
J
Jo Diesel
St. Johns MI
Progress
J
Jo Diesel
St. Johns MI
So far this is just me and the wife
J
Jo Diesel
St. Johns MI
Took a lot longer than expected glass on the roof and the balcony going up
J
Jo Diesel
St. Johns MI
Didn't like how the roof supports look so I added a beam
J
Jo Diesel
St. Johns MI
Been a long time since updates. got the stone veneer done. Still got railings on the balcony
J
Jo Diesel
St. Johns MI
A major problem came up. plugged drain from the sink to floor drains down to sump in pit plugged.
J
Jo Diesel
St. Johns MI
Hooked a bladder to end of some pex tubing and went up from the sump pit and got clog to let go. Was sure I was going to be busting up concrete
J
Jo Diesel
St. Johns MI
The rust on the steel beams jacked the concrete around the pit. Got it all cleaned out so we can clean and paint the beams before patching concrete
J
Jo Diesel
St. Johns MI
The busy part has been wheel bearings in the wife's car. I got her old CTS with a check engine light. Got to do timing chains. Following weekend transmission in my 05 Dodge with a Cummins. I hate working on my own vehicles. I work on big trucks for a fleet for a living
J
Jo Diesel
St. Johns MI
Got some holders with it and carbide inser6
xtremek
St. Johns, Mi
I hear you on dealing with your own stuff. I turned a wrench professionally for a few years. With our fleet, 4 cars, 3 trucks, a X-over, 3 trailers, and the 8n, it seems like I've always got something to work on. Ugh.
