Recommend me a wall mount fan
zkdiesel
chicagoland cornfields
Looking for a nice 24-30” multispeed Wall Mount fan with a bracket that can mount to a flat wall with atleast a 90* option for side to side swiveling
Low Noise output is a primary concern. Doesn’t need to oscillate
Good recommendations on something that’s not junk?
Toolfool
Tallahassee, FL
I bought 2 24" oscillating fans from Global Industrial. They move enough air on the low setting to make my mini-splits more efficient.
pbon
How low does the noise have to be? If you want CFM, it comes with noise.
pbon
The OEM Tools 24” wall mount gets good reviews. I have 7 of them in preschool classrooms. On low, you can have a conversation but you can definitely hear the fan. On medium or high you can still hear and talk but it’s louder. The pull chain is plastic — dumb, but for $7 and 10 minutes you can change the switch to one with a metal chain or for $13 you can buy a remote controlled outlet adapter that will turn the fan on and off at whatever speed the pull chain is set.
