Recommendation for Recessed lighting
75gmck25
Alexandria, VA
My basement workshop has a low ceiling (84"), so I want to get the lights up and out of the way as much as possible. I also want to use LED lights to take advantage of the power savings, low heat output, etc.
I already installed some HD 4" Halo housings and retrofit trim kits in the bathroom, but the housings were about $10 each and the trim kit with LED bulb combination was about $40. However, I need about 10 more lights for my work area, and don't want to pay $50 each just to get good light.
Any suggestions on a good brand and source for recessed new work housings and LED light and trim kits that would be cheaper than $50/light? I plan to finish most of the ceiling to get a nice reflective white surface, so at least 8 of the lights will need a trim kit.
Thanks,
Bruce
frankush
IL
The only way to get cheap LED is with the conversion kits. The Halo's are good cans. I think for what you're getting, $50 is a decent number and you'll have a tough time beating it.
bzinsky
Thanks,
Bruce
$20
http://www.homedepot.com/p/Commercial-Electric-4-in-White-LED-Recessed-Trim-CER4730BWH27/205116567
simpler=better
Baltimore, Maryland
I have 76" ceilings in my basement and have been happy with retrofit cans + HD store brand 6" LED retrofits. I believe the cans were $10 and the lights $30ish.
75gmck25
Alexandria, VA
Thanks for all the suggestions. It looks like Halo or Commercial Electric 6" cans and LED retrofit kits are the the most reasonable prices, especially if I get a discount by purchasing them in bulk. Now I just have to plan the layout and start installing.
Thanks again.
Bruce
arnoldcp
This will be my first post since joining so take it for what it's worth. I just recently added some of those commercial electric retrofits to our master bedroom. A few of them say on the box, junction box compatible. If you get those it's as simple as putting a blue plastic j-box where you want it and putting in the fixture. Saved me a lot of time and the cost of the cans I thought I needed.
Radix2
the thumb!, MI
With low ceilings I find can type lights to be poor for getting a good overall illumination for working (ok for Tv watching ect.) You need a zillion because they don't light up the ceiling and the spread downwards is poor. Small bright ones create glare. I did a test in my basemment and found 9 - 65W R30 bulbs in 6" cans gave an overall room appearance not all that much brighter than the single 60W bulb did in the old ceramic holder.
Personally I would go with flourescent tubes of some type if it is a work area to get bigger and softer light than you get from cans. YMMV
