Greetings!
I plan to install a 1 Ton (12,000 BTU) heat pump. I want to install wiring now and install the heat pump later (work on the panel is required). I want to install the wiring now because the roof is open (to this one story cottage)- making the task easy. Heat pumps in this size seem to be either 115v 15amp current (25amp breaker recommended) or a 230volt 10 amp current (15 amp breaker recommended).
What sort of wiring would be recommended for the 115volt system (10 or 12 gage, three wire) and, alternately what would be recommended for the 230 volt system (12 gage 4 wire)? MrCool equipment seems attractive (4th generation, Energy Star Ductless Mini-Split: DIY-12-HP-WM-115C25) although there is a lot of other manufacturers that are also attractive.
Thanks for your help!
