Recommended Tube Beading tool?
noid
Looking to create this:
What beading tool should I be looking at?
Sumboodie
AK
If it's small, a brake flare is what I do. Just use the 2nd stage part.
vssjim
McLean Va.
Need a size of tube to be used if it 5/16 or 3/8 Master Cool hydraulic flare tool kit does those type of tube fittings like a GM fuel line clip on fitting or o ring seal with tube nut behind
Rockable
Oak Ridge, NC
VintagAir has quite a selection of both hose fittings and tube assemblies with that end on it. You bend the tube assembly, as they come straight in assorted lengths.
