Reddy heater hookup question
kerwinq
Boise, Id
I picked up a used 80K btu Reddy heater with hose attached but the threaded end on the valve will not screw into the propane tank that I have, are there different thread sizes on the tanks that I am not able to thread it on? I have looked at the threads and they good. Would it be best to get a new one and not try to use the old one? If a new one is in the future are the ones for a BBQ the same as a heater?
Thanks, Kerwin
K
kerwinq
Boise, Id
I have never hooked up a propane tank before so didn't think of it being a left hand thread. That worked like a charm
That heater puts out a lot of heat in short order
Thanks
Charles (in GA)
50 mi south of Atlanta
You probably have a heater with the older style valve hookup. New tanks are required to have valving in them to prevent over pressurizing them (OPD valve) and it has (if I recall) an external Acme thread on it (and a special handle shape, a tri wing valve knob is required I think, as a form of ID) while the older tanks have a valve with internal threads and a typical round knob.
Do some google searches for Propane valves, OPD valves, etc and you will find all kinds of adapters, etc.
Charles
D.J.
New Haven IL
Sorry Charlie: But OPD stands for Overfill Protection Device. This is something I do know about since I fill gas grill bottles at my 7:30 - 4:30 job. You don't need an adapter because even the new style valves have the new style acme externaly and a POL threads internaly.
________
Fucktube
NUTTSGT
Northern Central Ohio
I'd imagine that 20 lb bottle won't last long with an 80k btu heater. You may want to check into having your local propane company bringing in a 100 or 200lb cylinder. Check out and compare the pricing, usually filling the bottles for grill is way more expensive than having a regular cylinder filled.
