Regulator, filter, desiccant filter. Which order for air lines?
signcrafter
Putting in the filters and regulator at the end of my air lines and wondering what order they should go in. Have a 175 psi two stage compressor and then I ran 3/4" black pipe air lines. Have 1/2" drop that will go to the filters and regulator and then to an air chuck and also a hose reel.
What is the best order to install these in? Regulator/filter/desiccant filter? Filter/desiccant filter/filter? Or some other order?
Fix Until Broke
SE Wisconsin
Filter First to get the particles and some water out
Desiccant Second to get the rest of the water out
Regulator Third so that it receives clean/dry air
sberry
Brethren, Michigan
You do not need the desiccant on every thing. I don't even have one. filter, then reg then dryer circuit where needed. Put a t on after the reg for any whips or assume its for air chuck and screw the reel to the other side of it. If there are only 1 or 2 outlets in the place with easy access then the service valve at the comp is fine, if there are several regs and circuits then a valve on the pipe ahead of the filter is good to provide local shut off.
signcrafter
That makes sense. Thanks.
I bought two nice new made in the us filters for not much money so I already have them and will use them.
Steve_P
Filter first is ideal but make sure it's rated for at least 175 PSI as many are not
signcrafter
I ended up going filter/regulator/desiccant. The filter/regulator is a combo unit with a special fitting between them so they had to go together. The filter and the regulator are both rated for 250 PSI if I remember right but I know I did check to make sure they are rated for my compressor. One of the reasons I went with the nicer industrial ones.
123Go
Well not to jumpstart an old thread but my regs after my filter fwiw & I never understood why so many are sold assembled opposite?
Really I wanted to mention I read many yrs ago to install them 25ft from your tank to allow the air to cool a bit? But idk how much or if it even matters really but Ive always done it.
Peace
