I just removed the floors from 2 40’ and 3 20’ containers. It took some trial and error. I started with a regular impact driver an a 1/4” #3 phillips. I burned up one driver, it is just too much for them. I own a 1/2“ Makita look alike 18v impact driver. I bought a drive head for 5/16“ impact Phillips bits in a #4. They worked well, but I was hoping for faster. I tried my air cat, even on the lowest setting it would snap the drive bits in a few hits. Back to the battery impact, it is what I used for the rest of them.
If you just jam it into the goo covering the screws and let it rip you will get about 75% of them unscrew. If the bit starts to spin stop immediately, then use a pocket knife and clean the debris out of the X and try again. If they just don’t seem to want to unscrew clean the X out with your knife (it makes a huge difference) and try again, still no joy, try to run it in a little then out. I used about 3 bits per 40’ container once I figured it out. The bits I used were Apex bits.
https://www.intlairtool.com/fastener-tools/bits/phillips-bits/phillips-5-16-insert-bits/
That is all my wisdom for doing it.
