NASTYZEN
This winter there were a few questions re fixing vented small engine blocks. This one didn't throw a rod but rather fell of the back of a truck, resulting in a cracked block. This is my technique of fixing them.
First I burn off the oil witch seeped into the porous Alu. Otherwise it's near impossible to weld up.
Next I wire brush the whole area clean. If you do this while it's still hot you also remove the top layer of oxide witch melts at a higher temperature than the base metal and also makes it hard to weld properly.
Then comes the die grinder to notch the crack to get better penetration and also removes some of the impurities.
I usually weld the inside first because there is always a little porosity from the impurities, then die grind the outside cracks right into the inside weld to make it as clean as possible.
Finally the outside gets welded up. Nowhere near the beauty of ZTfab's welds, but it does the job. It is a snow blower block after all.
