This is only partially related to my garage, but I'm sure some of you have gone through this before. Most of the details are below, but you can bypass the long winded version and skip straight to the question if you want.
I have a relatively new house (built in 2003) and this past week I discovered the windows on the 2nd floor above my bay window are allowing water to leak into the frame of the house. Luckily, the water is coming in between the brick front and the house wrap and hasn't from what I can tell come into contact with the OSB board. Unluckily, the leak was directly above my bay window as previously mentioned, so it destroyed all of the sheetrock and insulation on the bay ceiling. Picture below:
Through some tests, I figured out that the water is leaking through the window frame. The window has weep holes that allow water that runs down the window to go into the frame and is then supposed to exit via two lower weep holes...except the water just disappears and doesn't come out the weep holes.
The windows are MIWD brand 3500 series which actually just went through a class action settlement for this same problem. I can post links to this settlement if anyone is interested. I suspect the review process is going to take too long so I want to replace the windows before it does anymore damage and then worry about being reimbursed later.
Question:
The windows are new construction type which have a mounting fin so the nails/screws are installed from the outside directly to the wood framing of the window. This area is now covered up by brick so I'm guessing I have to cut the windows out from the inside?
Once I get the window out, what type should I get for the reinstall? New construction or replacement? The new construction would obviously require the nail fin to be removed, but that's easy with a utility knife and some flexing of the vinyl. There also appears to be some vinyl trim work between the window and the brick...
Any help would be greatly appreciated!
Window from the inside...trim work removed. Size 36x60, frame opening 36.5x60.5
Lower portion of window exterior mated to brick:
Upper portion of window exterior mated to brick:
Question:
