Rewiring home from 1947
AlexNGreen
Minneapolis, MN
Not necessarily garage related but anyways. My home was built in '47 and true to the era has the rubber and clothe insulated wire run through flexible metal conduit. As home improvements have progressed the horrible state of the wiring has been noticed. I have come to the realization that the wiring needs to be replaced.
My question:
I know THHN wire can be ran through the conduit but specifically can stranded THHN wire be ran? Also what sort of termination do you use at outlets and switches?
Thanks for looking-
Alex
Stuff
Double check as most likely you do not have flexible metal conduit. Most common for that era was AC (armor clad BX) wiring. You can not remove the individual wires from that.
RacerRick
Durham Region, Ontario, Canada
I just upgraded all the wiring in my old house. I didn't open the walls, but I have a bungalow with an unfinished attic and basement that had knob and tube wiring. Probably the easiest setup.
Depending on the style of the house it can range from "not hard" to "near impossible" to fish new Romex through the walls instead of opening them. I have never seen flexible conduit in a home, so I would agree that is is most likely BX, but I think the electricians on here probably know best.
rockwithjason
Las Vegas
depending on the location and the era there are many homes that have either hard pipe or flex in the walls. my brothers house was built in 1965 in san bernadino and it's 100% flex
Stuart in MN
Minneapolis
This is my suspicion as well. Make sure what's installed first, before doing anything.
