Ridiculous Rockwell Project
BFBOB
I have a Rockwell radial drill press I've posted about before. I picked it up at an estate sale for $87.50 - not a steal, but it did come with about 20 lbs of assorted drill bits, reamers and other tooling. It's definitely light duty, intended for woodworking - low speed is 750 rpm. I added an intermediate pulley to lower its range, which also raised the top speed. Now it's about 100 to 5000 rpm.
All sensible, but then I decided I didn't like the belt guard. It's just too plastic.
I liked the looks of the older cast iron guards, so I set about looking for one.
I found this one on eBay for about $50 w/shipping. I know. Ridiculous. But, I like the look - it reminds me of the monster's head in "Alien".
Of course, it mounts to the dp it came on in a different way from this one, so I made a mounting bracket. I started with a heavy ~1/8" piece of salvaged angle. A little cutting and bending matched it to the shape of the dp. Welding on some 1/8" flat created the flange to fiit into the groove on the dp. I'm not a great welder, but grinding v's and 80 amps with a 3/32 7014 rod got me enough penetration to grind the welds flat, just for the sake of appearance.
Now, I've got to strip and repaint it. I found a good match for the original gray: Rustoleum Painter's Touch Winter Gray. It's a gloss paint, but shouldn't look too slick on the rough cast iron. That's kind of a lot of gray, kind of drab. Maybe I'll add racing stripes.
Then, there's refurbishing the badge. I have a trick, but haven't tried it with color. Will report if it works!
Going to all this effort and expense for a modest little drill press is pretty ridiculous, but there might be a practical advantage too. I've always wanted to have an up-front bump-off switch, and maybe, just maybe, there will be room to mount one inside the guard without hitting the pulleys. We'll see.
Boilerhouse
Muskoka
Your Rockwell DP looks a lot like my Sears model which I bought new around 1985. I had a look at your speed reduction mod and will be following the others. My table is covered over with a larger piece of plywood. The only mod I did to mine was; I placed a scissor jack from a Corolla under the table to have a crude but effective table hand crank. I once also inspected the rack for some reason and managed to get the quill return spring to fly out it's housing. I can report with some authority to try and avoid that. :lol:
tool_scrounge
Southern California
For future reference for someone else not liking the plastic belt guard, Rockwell Delta made the earlier 11-100 drill press with a cast iron that appears to have the same mounting lip arrangement as the later plastic one. But the rounded cover is pretty cool.
BFBOB
Yeah, this DP was made in several guises - may still be in production for all I know. Since it's all about looks, not authenticity, I picked the belt guard I liked best. If it's any consolation, Scrounge, yours was my second choice.
I was joking about the racing stripes, but then thought, why not? So, here they are!
The badge is next. I found a really good graphic of the right one here: http://wiki.vintagemachinery.org/Decals-Delta-Rockwell.ashx
so I should be able to make a good copy
2oolhound
BC Canada
Nice work on your mount. Not sure if I like the red and white (if that's the plan) it does work with the badge. I'd paint the whole centre part that looks like it rises up from the rest of the guard all the same colour.
How about this -
Your mount and the red racing strip - black
The left and right sides - red
The raised up centre section - white
Squashfest81
Totally rediculous, but I've always wanted one of these radials too. Nice save.
ALLFAST
BFBOB,
Nice work ! I've been away from the GJ for a couple weeks and in the last few days discovered this Rustoleum Winter Gray as an option for a little project I'm hatching. The WG is the color on the left of your photo here, correct ?
TIA, Shawn
BFBOB
This photo here.
No, the left is the original plastic pullely guard, unpainted. The right is the new cast iron guard, sporting the Winter Gray paint. It turns out to be a good match, but much lighter than the rest of the press, which is better matched by Rusto Dark Machine Gray. I'll wait til it's all done and on the press before deciding whether to repaint with the darker gray.
At least I wouldn't have to go through paint stripper agony again!
