YoshiMoshi3
- Joined
- Nov 2, 2022
- Messages
- 520
I've seen lots of people convert non-right angle impact drivers into wrenches, by swapping out the anvil, but never a right angle impact driver. Has anyone ever done this conversion and had success, or could provide some tips on how to do so? I don't believe one is currently available commercial. That is a right angle impact WRENCH (not a driver).
Milwaukee 2668-20 M18 3/8 Right Angle Impact Wrench
Maximum torque of 675 in lb or 56.25 ft lb (Makita Website)
Overall tool height of 58.28 mm (see Project Farm Video, Height not provided on Milwaukee Website)
Milwaukee 2467-20 M12 Right Angle Impact Driver
www.milwaukeetool.com
Maximum torque of 600 in lb or 50 ft lb (Milwaukee Website)
Overall tool height of 56.86 mm (See Project Farm Video, Height not provided on Milwaukee Website)
Makita XLT01Z Right Angle Impact Driver
www.makitatools.com
Maximum Torque of 530 in lb or ~44.2 ft lb (Makita Website)
??? Cannot find overall dimensions
Skill RI574502 Right Angle Impact Driver
www.skil.com
Maximum torque of 900 in lb or 75 ft lb
Overall tool height of 66.08 mm (Project Farm Video)
Rigid R87730B
Maximum torque of 950 in lb or ~79.2 ft lb
??? Cannot find overall tool height
Project Farm Video:
(see 9:46)
Looking at the parts list on Milwaukee's website for for the M18 right angle impact driver. The M12 version does not show the internals of the head, only the M18:
It appears that the hammer (part 31) impacts the anvil (part 30) which is female with internal teeth. As the anvil rotates it turns Part 21 which rotates the 1/4 female hex that holds 1/4 hex bits. I just don't know if it is a special part that the pin (part 3) needs to go into.
It looks like a regular ratcheting mechanism that you would find in a hand ratchet.
Almost like I just put the anvil of a 1/4 hand ratchet into the right angle impact driver to get a 1/4 right angle impact driver.
Milwaukee does make a right angle impact wrench that is 3/8", 2668-20 https://www.milwaukeetool.com/Products/Power-Tools/Fastening/Impact-Wrenches/2668-20. It looks very similar to the two 1/4 right angle impact drivers they sell.
I'd imagine the right angle impact drivers from the other manufacturers would have similar internals.
For what it's worth, the 3/8" right angle impact wrench that provides much more power than the 2668-20, the 2564-20 (https://www.milwaukeetool.com/Products/Power-Tools/Fastening/Impact-Wrenches/2564-20), with 71.85 mm in overall tool height, or 14.99 mm shorter in overall height than the M12 2467-20.
Maybe if we could modify the Milwaukee 2467-20 M12 Right Angle Impact DRIVER into an impact WRENCH, it would be the lowest profile 1/4" impact wrench. It would save you 15 mm over the larger and much more power 3/8 impact wrench 2264-20, and allow you to use shallow 1/4" impact sockets, that are smaller in overall length than the 3/8" drive sockets. The Ko-Ken ones are about 9 mm shorter. So a modified 2564-20 would give you about 24 mm in extra space or about .95 inches. This might allow you to get your impact in a few additional spaces with not much clearance, so you don't have to resort to hand tools. I know some cases you just have to use hand tools, and not use non-impact tools. But the more places you can get your impact in the faster you can work.
M12™ 1/4" Hex Right Angle Impact Driver (Tool Only)
Makita USA - Product Details -XLT01Z
18V LXT® Lithium-Ion Cordless Angle Impact Driver, Tool Only
PWR CORE™ 12 Brushless 12V 1/4 IN. Hex Right Angle Impact Driver with PWR JUMP™ Charger
Make challenging projects a breeze with this impact driver set that includes a Brushless 12V Right Angle Impact Driver, a PWR CORE 2.0Ah Lithium Battery with PWR ASSIST Mobile Charging, and a PWR JUMP Charger.
Rigid R87730B
RIDGID 18V SubCompact Brushless Cordless Right Angle Impact Driver (Tool Only) R87730B - The Home Depot
Give a strong addition to your workstation with RIDGID SubCompact LithiumIon Cordless Brushless Impact Wrench with Belt Clip.
www.homedepot.com
Project Farm Video:
