Knyte Tyne
Good day GJ Family...
So I have a quick question for everyone. it pertains to running Compressor lines for Air in the 'Shop'...
So On my end of the world. Copper Piping is Prohibitively Expensive. I cant find decent Black or even Galv pipe and don't have a way to Thread them regardless...
So this got me thinking... I have just "upgraded" my compressor with a proper Rubber Hose and Connectors. (been using the Cheapo Expanda Hose that came with the Hobby unit)
Now I know PVC piping is an absolute no go...
But trying to run Flexible Rubber Hose neatly and straight without sag is nigh on impossible.
Now here is my idea...
Could I run my setup with the Rubber Hose as I intend to but inside the PVC piping? (its cheap and i can get many meters worth within my budget)
So basically like you would for electrical, Id install the Conduit but with the Rubber Hose Slipped inside with just the ends coming out each side with the connectors. The pipe would never be sealed so would never hold pressure should there be a leak in the Rubber hose for whatever reason one may occur. It means I can use all the bits and peices that let you Run Neat electrical conduit but inside there is my Air line...
Thoughts? Ideas? Improvements? Potential Pitfalls that I'm not seeing?
I hope this was the right section to post this... Will try get some Pics Up soon to better explain my though process...
Thank you all for the assistance and thoughts...
But trying to run Flexible Rubber Hose neatly and straight without sag is nigh on impossible.Now here is my idea...
