ryobi impact driver and drill
k-os
WI
I might be wrong, but I believe these have been on sale for 99 bucks. I bought them a few months ago, but can't remember what I paid?
That's right. Picked these up just before Father's day as a gift at $99.
DSM21
Throw a harbor freight 20 or 35% coupon and might have a killer deal on your hand
Wastegate
One thing to remember too is this set only has the 1.0 ah batteries, Smallest Ryobi offers and they do not last long in there other tools.
JonnyC
Green Bay, WI
That's the previous model impact as well. I bought the drill combo kit then dropped $70 on the impact driver. Not what I wanted to spend, but I love the thing.
elronin
Hialeah,Fl
They are back up to 129.99. I still have the old Nicad ones, in dark blue. I loved that old Impact driver, it was great for installing Tapcons for my Hurricane shutter rails. Best thing about the 18 volt Ryobi tools is you can use the new Lithium-Ion batteries on the old tools. Still don't know If I should sell my old 4 piece Nicad set for 20 bucks in a garage sale or buy new lithium Ion batteries for them?:dunno:
TheToolReviewGuy
cheechi
Triad, NC
I think they come with 1.3 or 1.6 Ah batteries in that kit. I'll check next time I've got one in hand.
Edit: my kit came with 2x P102 batteries that say 24Wh. which is of course 2.0 Ah. That's the best slim pack they make now, far as I know.
KaHuNaZ
Corpus Christi, TX
I would recommend holding out on this impact and getting the newer p236 Impact driver. The auto load chuck on the p236 makes all the difference, simply because you can change bits with one hand. When the chuck is released it completely ejects the bit then stays unlocked until you insert another bit.
It might not sound like much, but after using both on recent projects, I found myself fumbling trying to change bits on the older style impact.
As a bonus, the newer impact also has led's and 100 extra inch lbs of torque.
The p107 lithium"+" batteries are 28Wh.
mdbeck1
Norman, OK
TheToolReviewGuy
Keep the old stuff. The lithium batteries will make them work like new stuff. When the tools wear out go buy the new ones.
I've got both the low and high capacity lithium batteries. I use the low cap ones mostly for the drills and the higher cap ones for the skill saw and the sawzall.
cheechi
Triad, NC
How do you like that Ryobi circ saw? I still prefer my corded but the FIL might be making me buy him one.
mdbeck1
Norman, OK
The circular saw (CS) and sawzall both eat batteries (lithium) pretty quick but they get the small jobs done fairly well. The CS does a fairly good job for cutting small amounts of 1X and 2X material. If you need to cut a bunch set up the miter saw.
If you need to cut plywood (1/2" or better) have spare batteries around. You'll get two or three 8' cuts from a battery so for small jobs it does a good enough job. If you are going to frame a house go buy a CS with a cord.
The other day I needed to cut some corrugated steel. It was real light gauge and I had the CS handy. It was noisy and a little bit messy but it did the job. I was surprised.
BTW: I never had a battery powered CS before the lithium batteries came out. After using the CS with the lithium battery I tried to use it with the Ni
Cads.... That was a fail.
All in all... if you're not in a hurry and have plenty of batteries around the CS is okay. Just don't expect it to work hard all day on one battery.
KaHuNaZ
Corpus Christi, TX
I tried the same thing as I didn't have a jig saw or reciprocating saw at the time. It left the edges dangerously jagged and unusable for the project I was doing. I ended up cleaning and finishing my cuts with some huge tin snips. Im curious how well the circular saw would work with a finer toothed blade.
mdbeck1
Norman, OK
I'm putting the tin on top of a deer stand in the middle of nowhere. If someone gets cut on it they will probably have to try but... i'll still place the "rough" edges towared the higher side so it's harder to reach.
PugetDude
Superstition Mountains, AZ
Works well for smaller jobs or when you don't want to drag out the big corded saw fto make a a quick cut or two. Only caveat is make sure you have a sharp blade, it doesn't have the nuts to drive one that isn't...
