Scepter's Shop Build and Projects
zmotorsports
Northern Utah
I hope everyone had a great 4th of July weekend! Busy weekend for me as I worked in the sop all day Friday and part of the day Sunday and had family party on Saturday. Also went to see my folks on Sunday morning. More on that later.
I stopped in the tire shop last week to inquire about two new steers for the coach. The Goodyear G670s I had on just turned 7 and I just wasn't happy with the way they were wearing. I think I've said it before, but they were rivering on the outside edges. I suspect that the PO ran then underinflated for a period of time and they were developing knots on the sidewall. I just didn't trust them any more and when I'm sitting in the seat for 18 hours (sometimes), I don't want to sit there and worry about them. Are they still ok? Probably. Is it worth the risk? Nope. I also asked about the Mickey Thompson's I want to put on the Jeep and his price came back a little high on those. The steers he quoted basically what I can buy the tires for online with no tax, shipping, or install. Deal done.
First up though, was the exhaust brake install. Pretty straightforward, aside from not being able to thread the hose into the air cylinder with the solenoid connected on the other end. It's just wonky in there, and not a lot of room to move around. I prepped the fittings on the bench and went after it.
I swapped out the old push lock for a compression fitting. I find that these are much more likely to not leak after a removal and install. In this case, I just didn't have much room to cut the end off of the supply line. Certainly would have a leak if I just reinstalled the same fitting. Cheap insurance.
Nice Keith. I also prefer compression fittings, but there are simply some locations and applications where they are next to impossible to get wrenches into for tightening. When I do use PTC fittings in those situations, I make sure to buy good quality ones as they seem to seal up well and work as designed, just make sure to trim the line back beyond the last place the O-rings sealed. There are definitely different grades or quality in these fittings and not all are DOT approved.
Now for the coach. My idea was to jack stand the frame by raising the air suspension up, jack stand, then lower the front air bags, setting the frame down on the jack stands.
That wasn't to be. On Friday, I started this project thinking I knew how the suspension on the coach worked. So much for that. I ended up making another set of cribbing blocks, 16.5x16.5 with 3/4" plywood and 2x6's. I placed everything under the coach, got it all moved around close, raised the suspension, moved the stands into place, lowered the suspension and nothing. Jack stands were still in the same place they were before. My mind was blown. How could I lower the coach 4" and still not be touching the jack stands??? I tried again. Raise then dump the air (as opposed to just lowering it). Still nothing. I was flabbergasted. And not smart enough (apparently) to realize that my jack stands were under the air bags, not on top of them. Duh. That thought didn't dawn on me until I was telling my dad my issue on Sunday morning. Further adding to my frustration was the bent breaker bar from trying to get the lug nuts loose. That's the point at which I called it and worked on the Jeep on Friday.
Fast forward to Sunday morning. I went out to see my folks as I won't see them for a few weeks and pick up a new cheater pipe and a 3/4" impact. I was chatting with my dad about it and through that conversation I realized my mistake. To say I felt like an idiot is an understatement. But, live and learn. If I didn't want to know how this stuff works, I wouldn't be doing this work. In any case, I decided to lift from the font axle one side at a time and place jack stands under the axle. Once I looked further at the frame and suspension. I don't think I could place jack stands on the upper frame anyway due to clearance and the fact that the upper and lower are stacked on top of each other.
Originally I placed the jack stand under the frame net to that mud flap. You can also see the vertical piece in the background that runs up to the upper frame. I don't think I can place a jack stand under that area. Possibly I can. More on that in a the next picture.
Here's the front section, where I could possibly place another jack stand under the control arms. If I placed at all 4 corners, might work.
Here's that rear vertical piece behind the air bag. It just doesn't seem like the top is welded fully around where this piece attaches to the main top frame rail.
In the end, she's up on jack stands placed under the axle where the frame bolts to the axle.
Here you can see the rivering on the outside treads. Some are worse than others.
This one is particularly bad.
I also picked up a set of centramatics to go back with once the tires are mounted and balanced.
Loaded on the trailer. I strapped them down and delivered to the tire shop this morning and they'll be ready by lunch.
the only other thing I'll say about this is that the Icon 3/4" breaker bar did well on this job. It certainly flexed pretty good and withstood the 5' cheater pipe I had on it. 450 foot pounds is no joke for sure. All in, the worst part about this job was the lug nut torque.
Thanks for reading along.
Keith, I had to fabricate extensions for my jackstands that reach up far enough to grab the actual frame rail above the H-frame. You are correct that there is not much room under there so some creativity is in order. Most people just grab the H-frame or axle and lift at that point. I do as well, unless I am doing suspension work, then I like to have that H-frame free and able to move it about independently of the frame of the coach. If I am just doing tires/wheels or greasing, then I'll just lift at the axle and slide the standard jack stands under the axle and allow the coach to sit on the air springs, but when dealing with suspension I don't trust the air springs and want a good solid connection between my shop floor and the actual chassis rails of the coach.
Got the coach tires put back on last night, along with the centramatics. I cleaned up the rims best I could and cleaned up all the mating surfaces. One thing I found interesting during this whole process was the suspension on the coach. Jacking from the axle on one side raised essentially both sides at once. By the time I had the passenger side on the jack stand, most of the drivers wheel was off of the ground as well.
Don't mind the dirty wheel and tire. I'll clean those up.
Super excited to get the Jeep tires changed out finally. The old ones are so dang noisy I can barely hear myself think on the highway.
All tire dates are 1126 on the coach and Jeep save for one on the Jeep. It's a 1725. Not super happy about that, but I figure I'll run through them in 3 years or so. I also can't complain as I got them for a pretty decent price. The coach tires actually came in $100 cheaper all in than I could get them online for before taxes and shipping.
I am so glad to see that you didn't go back to those Goodyear's Keith. I couldn't get those damn things off of my coach fast enough when we bought it back in 2007.
I can't see the lettering on the Toyo tire, which did you go with, the M144 or something different?
ScepterToad
Thanks for the input Mike! I'm actually excited to see how you do the cribbing you've referenced as I have a few ideas myself. Like you, I do NOT want to be under the coach working on suspension or air system work without known good support. I'd love to see a picture of your extensions if you're willing to share that.
The Toyo's are M144s. Talking to the tire shop where I got them, he stated that the 144 is being phased out and will move to 154. I have not vetted that information. I have 144s on the rear as well.
As you may remember, I have a spare sitting in the basement of the coach. More than anything, it was peace of mind for me when I first got the coach. It's also a G670 (which is what I had at the time of purchase). Now that I've logged just about 30K miles with this coach, I'm much more comfortable in my own abilities in recognizing problems ahead of time and making sure that I maintain to the best of my abilities. Not that something can't happen, but I feel like it's a longer shot now.
So, I'm about 85% convinced I'll be getting rid of the spare and freeing up more space and weight.
zmotorsports
Northern Utah
Keith, sorry, I just couldn't see the lettering on the tire to see what model it was. I like my M144's that I've had on for a couple of years now. I didn't realize they were being phased out though.
I posted a couple of pictures of my modified jackstands a few years ago but after getting raked over the coals because I was not qualified to make such modifications, I removed all of the pictures I had posted from various forums. Seems like the keyboard warriors or keyboard professors are also engineers as well as lawyers.
Basically they are just 3.5" OD by .250" wall tubing, the same as the 22-ton jackstands use, but are about 2.5' in length. I cut a notch in the one end to accept a slight "V" and welded it so it acts as a cradle or saddle much like the original jackstands have. I then lay them down under the coach, stand them upright and cradle the frame rail just behind the axle and grab it right at the frame rail. Then let the air out of the system so it sits solidly on the jackstands. I do the front first, then run around to the rear and use another pair of 22-ton jackstands to reach up under near the rear frame rail where the hitch attaches. The rear requires me to slightly raise the coach using my 22/35 ton air over hydraulic jack to get just a couple of inches of height before the jackstands will slide under, then let it sit down solidly.
ScepterToad
Thanks Mike!
I sort of envisioned that's the way they might be.
signcrafter
You must not have shown close ups of your welds or they would have seen you are more then qualified Mike. Good thing they didn't see all the other stuff you have fabricated over the years, they probably would have banned you from the internet if you posted pics of go fast stuff and everything else. LOL
ScepterToad
I hope everyone had a great weekend. For once, I got a lot done around the house and it still seemed like it was two days and not one.
Saturday, we worked on the yard and got the grass mowed and the patio cleaned up a bit more. Transplanted a few tomato plants that weren't doing well in pots and then I headed over to the shop for some Jeep maintenance. First tire rotation on the new Mickey's, oil change, and transmission fluid/filter change. Not many pictures as I was on my back fighting the pan. I first got the Jeep up on jack stands so I could get the tires off and rotated. Pulled the transfer case skid plate, loosened the fuel tank skid plate, and pulled the main crossmember and the other little one in front of it. Not sure what it's called.
Fluid dumping into a pan following removal of all the stuff.
I used the floor jack to jack the transfer case to raise it enough to get the pan out. I'll never understand the placement of the exhaust crossover. I guess it has to go somewhere.
Overall, the fluid wasn't terrible. A bit stinky and turning brown, but no real material on the magnet, which I'm happy about. This is a 40K change interval. I may go to 30 next time, if I haven't swapped it yet by then.
Cleaned up.
I intended on going to the local NAPA for all of my parts. Unfortunately for me, they decided to change their hours to close at 2 on Saturday, when their website is published at 4. I was not happy. O-Reilley for the filter but the fluid was expensive and the Mobil 1 oil I use was almost double that of Walmart. So, off to Walmart I go. They had the oil and filter, but not the transmission fluid. BAck to Autozone. By the time I was done, I wasn't very happy. My own fault for not getting this stuff ahead of time.
Pan cleaned up.
A bit of sil-glyde on the o-ring of the filter.
Put it all back together then filled fluids and rotated tires. More to come.
ScepterToad
A few weeks ago, we went to the Highway 127 Yard Sale. This is a sale that runs the length of Highway 127, which runs from MI to AL. We started in Northern KY and headed south. Mostly junk, but there were a few things of interest here and there. Most folks didn't want an arm and a leg for tools, so I picked a few small items. First up, a body hammer. I don't really need one, but this caught my eye for some reason and I don't have one so I grabbed it for $3.
There aren't any markings on it, which is fine with me. I'll polish it up and put it in the toolbox.
The other tools. I'm kicking myself a bit on the wrench. I didn't have a 20mm in my box but the guy had a pretty complete set for $1 each. He would have made a deal. My thought at the time was that I already have multiples of every size up to 20, so I didn't really need it. However, once I got back to the shop I realized that I should have gotten them cheap. I could keep a set in the coach at least and not have to transfer tools. Lesson learned.
I also never had a speed handle. I used them a lot working on F-16s. This one appears to be a Bonney and spins real nice.
And probably the oldest tool. This tap handle is a Sawyer Tool Co. tap handle made in Fitchburg, Mass. They produced in Fitchburg from approximately 1900 to 1912. Pretty cool. The adjustment is free and just needs cleaned up a bit. I probably won't clean this one up much other as I don't want to lose the marking on it. All these were $1 each so I spent a total of $6.
I also started working on my tire carrier but screwed up already. I'll detail that more once I get that project back on track.
zmotorsports
Northern Utah
There are some nice scores there on tools Keith. I have a couple of old Snap-on speeders that I purchased new in the late 80's and I still use them to this day. The 1/4" not too awfully much, but I use the 3/8" speeded quite a bit, especially for starting lug nuts on vehicles.
ScepterToad
Thanks Mike! I'm excited to get back to a speed handle. They certainly make multiples of tasks go faster/easier.
WoodsTruck
I have a little hammer just about like that. I find use for it quite often. One thing I find handy, which Robert might find offense with, is as hammer extender. I can place it where I need to strike, then hit the other face with a second hammer. That way I can minimize impact marks and direct the impact where I need it if is in a tight spot where I can't get a decent swing.
