Scroll Saw
JSwaff19
I'm not the handiest person around here, but I've recently had an itch to start learning how to use a scroll saw.
As an obvious beginner...
- What do I need to know about them?
- What features should I look for when purchasing one?
- What is the best scroll saw out there for a rookie?
I have done a little research over the last few days but always know that I can count on everyone here for some in depth details and real life experiences. I know there are attachments available for certain saws also. If you have a picture, share your scroll saw set up and let me know what I need to get started.
mbatarga
GA
What is your budget? What type of projects are you interested in?
Typically - the more expensive models vibrate less - likely have variable speed and other features that are nice to have. The cheapest saws typically require blades that are Pin mounting style - which requires a larger starting hole for captured cutting. More expensive saws hold the blade with a clamping force - and therefore allow VERY small blades. Those small blades allow very precise cuts and small/intricate projects.
Dewalt has a model that runs about $400. The stand and light accessories, etc. -can add another $100-200.
nanofrog
I've a Delta of this type I bought it new in ~'86, and wouldn't trade it for the world.
In fact, this thread has reminded me I need to buy more blades. :D
bfm336
St. Louis, MO
Early 90s deltas - $30-60 at yard sales or pawn shops. Usually come in single or dual speed, the latter is nice if you find one.
Git
S Cal
Sounds like my Delta 40-601. I also bought one brand new from around that time period, although it has not seen much use lately. If you come across a used one, they have been known to have problems with the electronic speed control.
Here is a pic of what they look like (this isn't mine). Another great saw from that time period was made by Hegner. Here is a great example of one currently on eBay. The Delta and the Hegner were easily $1,000 brand new
http://www.ebay.com/itm/HEGNER-Mult...144739?hash=item2112baad63:g:x-YAAOSwkl5XfoeN
nanofrog
Mine's only a 40 560, so not that sophisticated. Does what I've needed it for though (cutting thin plywood, plastic, and FR4 PCB material), and still going strong. Spare parts are still available too. :thumbup:
Not my image either ^.
Maui
Upstate NY
A vintage Delta Milwaukee from the early 1950s with a 24" throat is an excellent choice if you run across one. They are built like tanks. The cast iron they are made from coupled with the geometry results in a machine that does a great job of minimizing vibration. I own two.
Maui
J
JSwaff19
After searching everywhere I could over the last week (prior to this original post), this morning I stumbled upon a Dewalt DW788 on a facebook resale group. The guy was asking $250 for it but it had been posted since March with no bites. I sent him a message and offered $200. He met me half way at $225. I picked it up this evening. He had two of them and needed to downsize so he parted ways with one. It appears to be in excellent shape!
