Sealant - Exterior Electrical Meter
thehorse13
Jefferson County, WV
When my home was built, the contractor used what appears to be big box store foam sealant around the exterior electrical meter. The box is mounted to the side of my house, which is wood construction, and the box has a quarter inch gap all the way around.
I know that I will need to clean out all of the existing foam sealant as it has weathered badly and literally crumbles off the house. My question to all of you is what kind of sealant can I buy that will last longer than the foam in a can from Home Depot?
Thanks!
tfi racing
Cedar,BC
Not sure why you would want to do that.It rains here almost all year round and nobody caulks or seals their meter bases at all...
Norcal
They are made to have the required 1/4" spacing at the back of raintight enclosures.
Slowgsr
Southern ontario
When I do any caulking outdoors I use poly based paintable stuff for anything that I need to tool or have a great appearance, if it's non exposed or for flashing in hard to see areas I use butyl rubber sealant which is impossible to tool so you need to be well prepared.
Speedy Petey
NY State
The 1/4 inch gap exposes the OSB to the weather. I don't want rot or bugs taking hold near the box.
The meter SHOULD NOT have been mounted directly to the OSB/sheathing.
If it was I guess you have to deal with it the best you can.
If I have to do a service before siding is up I put blocking behind the meter pan.
Slowgsr
Southern ontario
Yeah - I use the standoff brackets
