MossBerg590
- Joined
- Jan 22, 2025
- Messages
- 8
I am converting part of my garage to a bedroom and was
building a wall in front of the garage door. I started with
a wood door, not well sealed. put a new door bottom
seal and added a seal on the ground. I put 2 r-tech
foam boards over the front of the garage. I added some
weatherstripping around the edges of the door on the
inside and then started framing and adding r-13 . I ran
out so I stopped for the day and nowl can see there is
moisture between the foam board and r-13. Idk if I need
to stop and start taking the r1 3 out and trying to seal the
door better? Maybe the weather stripping isn't sealing
properly? Or where the door panels meet eachother?
Any ideas are appreciated. It got down to 26*
this morning and then about 44* now when 1 saw it.
Any ideas are appreciated. It got down to 26*this morning and then about 44* now when 1 saw it.
