Seam sealer suggestions
bgoodwin
Iowa
Question for some of you guys that do body work. The project, I found a rust free box for my sons '76 GMC and am getting it ready to paint and install. The seam sealer in the box around the edges and over the wheel wells was dry and cracking so I pulled and ground it all out. After getting the paint done I plan to use a spray or roll in bed liner so appearance of the sealer is not real important. The question is what should I use for seam sealer and should it be brush on or from a caulking tube?
larry_g
oregon
The auto store sells a specific product called seam sealer made specifically for the job at hand. Sorry its been to many years since I bought it to quote you a brand. It is a thick goo that you put on with a trowel or putty knife.
lg
no neat sig line
Professur
Mo-Ray-Al, K-bec, Ka-Na-Da
As a rule when I'm doing a lap joint, I spray the inside of both sides with a weldable primer, weld it up, then use a caulk gun dispensed 3M product. Couldn't tell you the part number, but it's what Carquest has on the shelf.
SM Racing
Huntsville, AL
3M Seam sealer is great stuff, use it all the time. It is white though, but it works great. Body shop supply houses have it.
