Sharing ground with generator?
pr3dict
So I just submitted my permit application today and I'm not entirely sure my design is ok...
I am looking to install a new sub panel in a new detached garage I'm putting up. At the same time I'm looking to install a whole house 22kw generator behind the garage.
The run to the garage from my existing Main panel is 230' and to the generator is ~260'. So using one conduit run is preferred.
100 amps for the generator. - Because of the distance I need 4/0 XHHW
60 amps for the sub panel. - Again distance 1/0 cable.
So as individual circuits these would be run as 6 individual cables inside the conduit but can I save some money and bond the two grounds together at the junction box like I have shown? As I read up on this it seems that this only ok if the circuits come from the same panel but the generator is going to a transfer switch and the ground from the sub panel would go to the "existing" Main (which will become a sub panel after the ATS is installed)
Any thoughts on this or should I give up trying to save money on 1 wire even though it's ~230 feet of it?
Generator wires should all go to ATS
You need 4-wires for each feeder NOT 3.
Your picture didnt post because you do not have enough posts yet. You need 6....
Stuart in MN
Minneapolis
The picture didn't show because you need to change the 'https' to 'http' in the address for imgur files to get them to appear:
P
pr3dict
ah typo on the 3 vs 4 wire. but my question really boils down to this.
Sub panel = 2 hot, 1 neutral, 1 ground
Generator = 2 hot, 1 neutral, 1 ground
right before the conduit to the house can I bond the two grounds together so I only use 7 wires instead of 8? 4 hots, 2 neutrals, 1 ground?
