Hello all. I'm relatively new here but I've been enjoying everybody else's posts about their garages and other shop projects. Since I'm just starting to build mine I figured I'd post up here to contribute to the forum.
I've been wanting to replace our rotting, old backyard shed since last year. But due to economic concerns we put off that project until a) we were on better economic footing and b) for a change of seasons and good weather. Since both of these conditions have been met, we're proceeding with the project.
Most of the written info to go along with the pictures will be posted on my website where the content is presented in a much nicer format, along with links to larger photos if anyone is interested.
Since I've already got a bit of a start here's a big rush of images in the first post. Updates will probably slow a bit after this and match progress. I'm figuring with my spare time out look that I'll be working on this for several months with a goal of completion before the bad weather returns in early fall.
PROJECT SCOPE & DESIGN
The scope of this project involves tearing down the old shed (work currently in progress), prepping the site, and then building the new shed in it's place. The "shed" is arranged in two structures: the larger main shed of about 180 sf and a separate smaller structure of 72 sf for the yard tools. Total square footage is over 250 sf of storage. Our local codes allow up to 200 sf per structure to be built without a permit, this is part of the reason for splitting the project into two structures. The other was to separate the "dirty" yard tools from a cleaner storage environment for other tools and materials.
Due to budgets constraints and anticipated usage, this will largely be for storage. It will be used in conjuction with the main house garage, however. The garage space will be the flexible workspace for future projects and I'll run the equipment and tools I'll need over from the shed. This will allow the work space in the garage to be configured on an as-needed basis.
A rain screen siding system will be used to clad the exterior of both structures. And the foundation wall will rise higher than necessary and project proud of the siding face to give the buildings a pronounced base or plinth to rest on.
Unlike many sheds that use pier blocks and wood floors, this will have a concrete stem wall and footing with a slab on grade floor for durability and long-term integrity.
Site plan.
Floor plan.
West elevation.
3D model of our property, house, back patio, and the shed.
Close up rendering of the shed proper and the yard tool companion building.
Section perspective cut through the main shed building.
View looking out across the new patio (to be poured at the same time as the
shed footing) to the shed in the southwest corner of our property.
BEFORE PHOTOS
The existing shed dates back close to 40 years. Over that time it has been remodeled at least twice with two additions. The first expanded the internal storage and changed the roof from a symetrical gable to an asymetrical one. The second addition added an enclosed, elevated play structure that was poorly details. The poor details left a large gap between a wall and roof intersection that let rain in to the interior of the structure. Between this and poor clearance between the base of the wood walls and surrounding grade the whole structure is in an advanced state of rot and decay.
Panoramic image of our back yard and the existing shed.
The shed back behind some vegetation.
The existing shed is rotting to pieces.
Shed Project
Kenmore, WA
Kenmore, WA
Site plan.
Floor plan.
West elevation.
BEFORE PHOTOS
I'm trying to layout my garage with a cheap CAD program and I'm still trying to climb the learning curve!
. I can't wait to see the build going on
Great photo, renderings and attention to details
