emeraldcoupe
sorry if that sounds dumb. i'm getting the gas conversion kit for my linc weld pac 100. i don't do a ton of welding, does the gas "go bad" after sitting for a certian time? thanks!
The most common for mild steel is C25, which is 75% Carbon Dioxide and 25% Argon.
Three reasons to store it without the regulator (not including OSHA rules):
1) So that in the 360 days a year you're not using it, no one turns the valve to 'see what will happen.'
2) Because the different components of a regulator are more likely to leak gas than the single main valve.
3) So that if it gets knocked over, the regulator doesn't snap off at the neck and turn the thing into a missile.
None of these are as big a concern if you keep the unit locked up, or use it regularly enough so that leaks become apparent right away.
