Shop floor sealing questions
Ohio Auto
30 x 48 shop, 7 years old concrete floor, moderate staining from wrenching.
I want to clean up the floor and put down a clear coat sealer, for gloss and protection.
Not really interested in breaking the bank for some top end look, just want to clean it up and seal it.
If I sand it can I just put sealer on top when I'm done, what's a good sealer, etc... Thanks
Garage Flooring
Grand Junction, CO
YES. ALWAYS check the chemical resistance of any product you purchase for this type of application. I just took a snap shot of the TLPPC TDS and attached the section on chemical resistance
Armorpoxy
Hi
Our SPGX one part polyurea in clear would be a reasonably priced solution for clear and that is super chemical/solvent/fuel resistant.
O
Ohio Auto
After research...can I just clean the floor without sanding and use the TLPPC?
Shea
California
Yes you can. Just make sure that areas where the old stains were at will absorb water. It they don't, they will not allow the TLPPC to penetrate either.
