Shop/Garage floor reseal help needed..please
Ohio Auto
Roughly 1500 sq ft shop floor. Approximately 3 years old, never sealed when new. I've worked a lot in it wrenching on cars so it has oil/grease/gas staining.
My goal: I want to clean it up best I can and seal it with something that will be somewhat shiny and protect it from further staining.
What method do I use to clean it up? Are there any heavy duty cleaning products I can use so I don't have to sand or acid etch the floor?
Plus...what brand of sealer can I use that can handle petroleum products and brake fluid?
Thanks..I really need some input here.
mato
Cleveland, OH
I would clean it with some light duty concrete cleaner and a walk-behind scrubber. Then seal it with a densifier or a epoxy/urethane system
darkk
Willimantic, Ct.
I think I may try this because epoxy coatings are never going to stand up to my abuse...I got this on a floor sealing site somewhere.
How to Make and Apply Your Own Concrete Sealer
ShareThis
Print this
Add Your Own Project
comments
Although it is hard to replicate a high quality concrete sealer, there is a good ingredient that can be used to make an effective and eco-friendly one – linseed oil. A concrete sealer is designed to keep water from entering the pores of the concrete in order to avoid damage. Moisture is a very potentially damaging factor that must be avoided by applying a good sealer. Read on for more information regarding how to make a concrete sealer and how to apply it.
Tools and Materials
Linseed Oil
Mineral Spirits
Measuring Cup
Plastic Container
Brush or Cloth
Step 1 – Mixing the Concrete Sealer
In order to make the linseed oil dry effectively on the concrete structure, it needs to be boiled. “Boiled” means to add a solvent to it to enable it to dry out quickly. Without the solvent, raw linseed oil will take forever to dry. Linseed is a natural product that comes from the flax plant. It is yellow in color and can produce a quality water seal when dried. In order to make it boiled, mineral spirit has to be added to it. Mineral spirit is a mild solvent and is a more eco-friendly solvent than turpentine. Mix one part of linseed oil to three parts of mineral spirits in a plastic container. Never use a metal container because it may react to the mixture.
Step 2 – Applying the Concrete Sealer to the Concrete
The sealer should never be applied to wet or damp concrete as it may not allow the linseed solution to dry or to seal effectively. The concrete should also be free from dirt and other contaminants such as other oils or paint. Pour the sealer into a container and use a paint roller, brush or cloth to apply it on the concrete. When applying the sealer, do not apply heavily, as heavy coats of linseed sealer will take a very long time to dry. The trick to sealing the concrete effectively is to apply thin coats.
Step 3 – Wait for the First Coat to Dry
Do not make haste when coating. Allow the first coat to dry completely before proceeding with the next coat. It will take about 24 hours to 48 hours for it to dry. In order to ensure that the linseed sealer will dry out to an effective water seal, do not apply it during very cold weather.
Step 4 – Apply Additional Coats
Since the first coat is a very thin coat, it needs to be made effective by applying a second and even a third coat. Make sure that the first coating has dried out completely before adding the second coat. As with the first, apply the second coat as thinly as possible to ensure faster drying time. Allow the second coat to dry before applying a third or possibly a fourth coat.
Tips:
When applying linseed sealer, never do so near an open flame or while smoking. The compound is quite flammable so observe caution.
Read more: http://www.doityourself.com/stry/how-to-make-and-apply-your-own-concrete-sealer#ixzz1JytCWkml
O
Ohio Auto
mato
Cleveland, OH
What is that?
A surface densifier seals, hardens, and densifies the surface of your concrete. It makes your floors easier to clean and maintain and gives some chemical resistance. Also, certain manufacturers products will have a glossy appearance to reflect light and give a 'brighter feel'
Think - Home Depot, Lowes, Walmart, etc.. they have densifiers written into their specs for floors when building new stores
Thanks for the link...that's what I was looking for. What kind of surface prep do I need?? Can I use aggressive cleaner with a floor scrubber?? Or are there any other recommendations? Does Legacy have a good cleaner and does GJ members get any discounts?? :)
If you have staining on your floor, your other option would be to mechanically prep the surface with a shot blasting machine. This should remove a majority of the staining. If you have any deep staining (oil), you will need to chemically clean those areas.
Once prep is done, you need to put an epoxy down (primer) before top-coating with a urethane
