Siga and Rockwool . . . worth the $?
Mr onetwo
Coastal Maine
In my area Comfortboard 80 costs as much as spray foam per sq ft. I priced the SEGA product last year and it would have added about $2500 extra to a 30x40x14 building. I love RR Buildings but he doesn't pay for anything in that shop.Sort of like most of the wildly expensive stuff they use on "This Old House"
N
It's finding the product data for the soffit and ridge vents and doing the math.
I found one Certainteed 12" vented vinyl soffit and it said 5.9 SQ IN per foot. Ridge vents I find are 18 SQ IN per foot You building is 30' wide. 1/150 is .2 SF, 1/300 is .1 Soffit both sides - 11.8 SQ IN is .082 SF Ridge vent is .125. Together over .2 or a touch more than 1/150. I wish the ridge vent was half the NFA, which would be near that 60% soffit and 40% ridge and 1/200.
My instinct is you definitely don't want more ridge than soffit and would be better off with less than 1/150.
Greetings again Mr. Conner:
My builder used vented vinyl soffit the entire eave and gable! I think they need to come back and redo this based on your assessment. You are saying that my ridge vent should be 1/2 the size?
Thanks in advance as always.
kngelv
Detroit, MI
How much air will get through this without a plastic barrier. I just built a garage with OSB, Tyvek and vinyl siding. I have R-23 rockwool to install in the 2" x 6" walls. I plan on 1" x 8" by 12' long pine carsiding panels for the walls and ceiling. Will adding a plastic or siga barrier make that much of a difference?
James
N
Hi James. I am not sure, but I am going the Siga route per direction given directly by Rockwool and the Siga folks. The Rockwool folks also suggested CertainTeed Membrain or Pro Clima Intello. Do note I am in climate zone 5A.
My interior was put on hold for at least a year, but I have roughly 1/2 of my walls filled with R23 Rockwool in just under 3 days of work - cannot stress how easy this stuff is to work with - like giant pieces of cake!
Where did you purchase your "1" x 8" by 12' long pine carsiding panels"? I may have to steal your idea!
finn
The UP, God's country
Rockwool was recommended when I built my free standing sauna last year, so I gave it a shot.. it’s supposedly mold resistant in a humid environment, rodent resistant, and a good product to control noise.
I can’t vouch for the rodent resistance (yet), or the mold resistance, but the building is very quiet.
The Rockwool was probably 50-100% more expensive, which didn’t really amount to much for such a small building.
There’s no integral moisture barrier, which adds a step to the installation process.
There’s stuff has poor structural integrity, and it’s heavy. I had problems with it disintegrating and collapsing under its own weight when insulating the ceiling. Once it falls, it breaks apart and has to be disguarded.
I wouldn’t use it on a ceiling again because of that. I had no issues on the walls, though.
My opinion: not worth it except if noise reduction is an important objective, like a house near a highway or airport.
Mr onetwo
Coastal Maine
I am going to use TimberHP for my wall insulation and Oskorp VARISMART DUO+ for the intelligent vapor barrier in my 40x30 shop. Based on 1440 sq ft the Timber HP is around $1000 less and the Oskorp 40% less. I talked directly to the factory and they stated that the smart vapor barrier is imperative to a proper installation. Poly is a no-no. Rockwool just had a fairly substantial price increase last week and I don't know if that is reflected in my comparison. There is no shipping as it is locally made.
https://oskorp.com/varismart-duo
Overboost44
MD
Thanks for this. I am getting to that point where I will need to start checking prices on all of this. Was set on getting rockwool but it was expensive enough without a price increase. Will look into the varismart but don't think I will need a vapor barrier with radiant and mini-splits on the inside and zip sheathing on the outside.
pcmeiners
Attic venting is working against the ceiling insulation in sucking interior air through it.
Yes working against fiberglass but not cellulose, fiberglass loses r value as the temperature drops. A few inches of cellulose packs down allowing very little air/moisture movement through it; cellulose only gets better the thicker it is installed. The only major negative of cellulose is if it gets thoroughly wet over a water affected material such as Sheetreock. Poorly ventilated attics work against asphalt shingles due to the heat.
