SK Hex bit sockets
Yankee
Midwest
Anybody have these? Hex sockets I like to buy decent quality since these is a lot of poor stuff out there and most situations it pays to get the good stuff..
Does Wright make any?
Aqua-Andy
SK makes great tools but If there warranty has not changed the bits in the sockets are not warrantied. The best in my opinion are Snap On.
ihateminimumwage
I personally didn't like the clip retention used on the SK 3/8" bit sockets I had. Too much play from the socket to the bit. I prefer a nice pressed in set, or the larger SKs with a roll pin through them. I've had an older Armstrong made set of Kobalt 3/8" for years now with no issues. Recently got some really nice Williams 1/4" drives that have been awesome, and I wouldn't hesitate to buy them in 3/8" if I needed them (SAE are USA and Metric are Taiwan).
mikebaker1129
Huffman,TX
Yes on Wright,they do make them. The new SK design is a friction fit and they are of good quality,as were the older type with the set screw.
The bit in my SK was warrantied .
The c clip retention type were very sloppy.
Williams USA are top notch as well.
Wes J
Peoria, IL
Stay away from the hex sockets where the bit size is reduced where it goes into the socket. 3/8 and 10mm are often done like that by companies that should know better. I've broken enough to say that's a **** design.
Fedwrench
Valley of the sun
I don't have any current production SK bit sockets but, I've had problems breaking my SK 7 & 8 mm bit socket bases or the chrome bit holder. I don't think I was abusing them and I was using them on a long handled 3/8 drive flex head ratchet. I prefer to use the one piece impact rated hex bits from VIM and Blackhawk.
davethorik
Norka, Ohio
I have an SK 3/8 drive sae set, it's ok but all the small sockets have the bit pressed in, and the 3/8 has a roll pin with what I would term excessive slop, been like that since new.
I then found a steal on a set of Wright 1/2 drive sae. These are great sockets, my only complaints are the plastic case they come in is stupid, should just come on a plastic rail like their other socket sets. Also, Wright has a more limited size selection than other brands. The set I have only goes to 5/8, I needed a 3/4 so I bought that size in Proto.
Y
Yankee
Midwest
Thanks for the replies, got me looking around since it sounds like SK is decent but may be better options out there.
Specifically I'm looking for a SAE 1/4 drive set. I have a metric Gearwrench set that is just "ok".
I looked at Snapon and it's just too much for my budget. ($195)
It looks like the Williams is Tiawan (I prefer to stay with US)
I do see that Proto has a U.S. Made set for under $70.....
bigjeff94
USA
I work as a millwright I have a shallow set of sk sae hex bit sockets they are awesome and are real good quality. However I do use my westward long ball ends considerably more do to the long recess in a lot of set screws in equipment
bob15
Northeasten, CT
DON'T buy the Wright set (or any company's with stepped bits) unless you like to keep extra bits around. When a stepped bit breaks you need to get replacement bits.
With the Snap On, older Protos (not sure on their newer stuff), Bonney's and probably a couple others companies; if a bit breaks, you can take a regular "L" key (Allen wrench), cut it to length and insert it into the socket and you are back in business. Cannot do that with stepped bit sockets.
I also find Wright bits too brittle and snap too easily.
Used socket bit tools would be a real good option, money saver and allow you to get the best tool style out there.
The pictures are of both style hex socket, with both being 3/16 bits.
dutchgray
Dorset. England.
That above although I don't mind the stepped bits if they are small sizes and are 1/4" hex so you can use ordinary driver bits, but you need the strait style for long bits really.
