smallest "radius" 12-pt box wrenches?
sonoronos
Hi all,
I figured you experts would know the answer to this one, pretty easily.
Does anyone know what manufacturer/model makes box wrenches with the smallest outside radius on the "box"?
I've attached a photo, since the terms are a little vague.
Basically, the wrench pictured is 9/16". The desired outside diameter is as close to 0.72" as possible.
I understand that the maximum torque that one can apply with this geometry is limited, but I don't really care. It really doesn't matter for the application. What matters is the outer diameter of the "box".
The easiest thing to do is to make my own tool by cutting a 9/16 12pt socket and welding on my own handle, but I figured I'd save my own time if I could.
firebox40dash5
I got tired of trying to do trig in my head and just measured a 9/16 12pt Craftsman USA chrome. I got right around 21/32 major ID- as in across 2 opposite points. That leaves right around 1/32 of 'meat' around those points... yeesh. Good luck!
BlueBomber
Outside Boston, MA
Hi all,
To be a MOTO (Master of the Obvious), you could just take any manufacturer's 9/16" wrench and then just grind down the outside until it reaches the radius you need. Lots of places you can pick up a 9/16" box end for cheap (garage sales, yard sales, flea markets, etc).
LXCam
I've done this several times. Just last year I needed to cut down a SK socket .100 in order to tighten some lug nuts in a adapter and had zero faith it would hold 100ftlbs of torque and was very surprised it did. I feel the key here is to start out with a good quality tool.
leg17
Kentucky
So, in keeping with the MOTO theme, get a Snap-On socket and grind it down.
LXCam
I wouldn't say that. But I sure wouldn't be grinding down a great neck or HF tool that for sure. :lol_hitti
losvre
UK
Hi all,
This one is very close to what you need, 18.5mm vs 18.3 (0.72")
http://www.tbs-aachen.de/Stahlwille...16_Double_ended_ring_spanners_i3565_50628.htm
Sent from my SM-A510F using Tapatalk
sonoronos
thanks folks....good call on grinding down the cheap wrenches. i was hoping to find a set, but i needed the 9/16 first.
thanks for the brainpower!
Sent from my SM-G920P using Tapatalk
californiaHank
firebox40dash5:
On the Stahlwille dimensions: You're probably not crazy, and I think you're right on this one.
losvre
UK
You are right guys.
Stahlwile is still is quite slim and very strong compared to many others.
You could actually use the 1/2" size and file from the inside. That way you need to file less, 1.5 mm or even less considering the tolerances.
Just an idea
sonoronos
Yes, this is why grinding is a bit of a risk, at that wall thickness, I'd want to the diameter to be as uniform as possible.
In tension, 1/32 steel is still extremely tough. In tool steel, it's even tougher. Total instantaneous torque in my application will be less than 45 ft-lbs. On average, I'll probably be applying 20-25 ft-lbs.
If I grind, I'm grinding a harbor freight wrench or a one-off home depot or lowes wrench. I don't think Snap on is able to practice black-arts metallurgy or has possession of ultra-secret steel recipes with magical heat treating capability. And Snap-On is expensive as heck!
Actually, the filing idea is awesome as well. Easy to try both, considering a 1/2 and a 9/16 share the same body!
BlueBomber
Outside Boston, MA
I have several box end wrenches in my collection that have had this modification done to them to fit into a tight space. You can probably use any good forged steel wrench (US-made or not) and it'll do just fine in a low torque application. Good luck!
Cruzan80
Denver, CO
Stupid question, but why not use an open-ended wrench? You end up with no clearance past the bolt needed. Unless you need 200+deg of thin-ness.
potato
thinnest box ends i have are on a zero offset set.
this style.
6PTsocket
Hi all,
Where I worked there were rotary solenoids that were frequently replaced, that were held by bolts with 10mm heads. They were so close to an obstruction that I ground down the box end of my wrench and those of several co workers. Just get a flea market wrench and grind away. You can sneak up on the right amount without
taking off more than necessary.
