Snap On gold colored Torx bits?
md21722
Mt Juliet, TN
I recently picked up a set. What I've found is they don't seem to sit as far into the bolt, but fit very tight. My standard Snap Ons go farther down but can be rotated back and forth a little. This is on a Jeep, if that matters. Is this an acceptable trade off? Should I look to another brand? Anybody know the durability of Stahlwille, Hazet, or other top brands by comparison?
JeepsAreBuilt
The Beautiful NorthWest
Are you sure its not a torx plus bit or a torx plus fastener ?
I dont have any gold torx.. my snappy guy dosent stock it on his truck, so I just buy the standard ones. I dont wanna wait 2 weeks for him to order one if needed.
drewvdw
Central Illinois
I've noticed the same thing. After a while they wear down just a bit and fit just fine. I haven't had any real issues with them, and no replacing the t20 every time I used it like the standard ones.
md21722
Mt Juliet, TN
That's kind of interesting, I would've expected them to fit right the first time I used them.
Ratchet.
Northwich England
I have had a bunch of issues with some of the gold ones, supposedly they are stronger than the steel colored ones but had my 40 torx bit replaced twice under warranty as was poorly formed and kept 'camming out' of fasteners as the end was undersized/tapered and was a very loose fit, current one isn't a whole lot better either...
according to my dealer there was a bad batch of them, whether that is true though im not sure.
md21722
Mt Juliet, TN
Interesting. So if I had unlimited options, would Hazet, Stahwille, Wiha, etc. be better? I looked at the Bondhus ones, they are listed as 2" bits which is too long for some applications.
T45
I've seen this before as well.
Maybe add Apex Torxalign on your shortlist.
Stevenn1
USA
They do look the same at a quick glance....
md21722
Mt Juliet, TN
Yeah, I've never tried to shove a torx plus in them, but they are the pointed bolts.... I've had the 01 XJ since '04. Looks like the picture on the left so I never even tried the torx plus.
Wakefield
Arlington VA (but would like to get out to country
Looking at a small (like T25)fastener it is very hard for my eyes to see the difference without a magnifying glass.
They should have started with Torx Plus and skipped the other one.
Fairly long discussion a while back in here about Torx and some other similar fastener drive systems. "Ribe"?
rustbucket5
i find the torx plus to be a better design, doesnt mis align as easy. i have the otc master set and its great for the $70 i paid. i heard the snappy gold bits were supposed to be the cats ****
shockwave
Marietta,ga
I find the gold coating on them adds strength and durable but can easily strip since its stronger than fastener I am removing I good example is brake rotor screws that have thread lock on them
abvw
Toronto, Canada
The gold bits are flat at the Torx end (sharper edges to grab the fastener), where as the regular ones are slightly convex which fits the concave broach of the fastener. This is why the regular bits seem to fit better, but you should get a better bite with the gold bits.
I noticed on the smaller sizes the gold bits are tapered differently down the hex stock to achieve a thicker profile.
The gold bits are also heat treated differently so they are less prone to breaking. They are supposed to twist and deform but not shear off and potentially cause FOD.
Skin
Boston
Noticed this with mine also so I don't use them if they don't seat properly. The VIM ones fit much better and are generally what I used most.
Sorry but that's just not true, they're literally too fat to fit in the torx properly so they sit on top. They wont bite better.
Who told you there was a treatment difference? The gold is a Ti coating which is hard and brittle, not soft. They don't twist, they just snap, the regular ones twist though.
Forgive me but it seems like you or your dealer or whomever are just making excuses because its "Snap-On". The gold bits have been hit/miss in fitment for years and its mostly random QC fails due to the coating making the bit just a hair too large.
Camping57
The gold Sanp-on bits are made to the high end of the tolerance range to provide a slightly larger amount of metal in the bit and a tighter fit, bothof which will tend to make them perform better with tight screws. But there is always a trade-off: they will have a real hard time going into a recess with any paint or debris in it. They also will have a greater tendency to ream out the recess on softer (lower strength) bolts and screws, because of the difference in material hardness.
Torx came out in the mid 70s and Torx Plus came out in the mid 90s. Given the age of those Jeeps and the fact that the American car companies were late to start using Torx Plus, I would say that those screws have good old Torx recesses in them.
