Believe it or not the solar technology has advanced to the point of just install a solar panel, wiring in a special box called a microinverter (solar panel in, cord out) and plugging into an outlet !
This type of setup is meant to augment your existing PoCo supplied power. Because it is very limited wattage (300W-400W ?) and because it literally plugs into and existing outlet, they "get around" a lot of expensive "issues" (no second meter, no disconnect, etc.)
Each panel and inverter feeds a 120V circuit. One microinverter per circuit, but you can have multi- microinverters as long as they are all on separate circuits.
Has anyone installed a system like this ?
