I am going to run a 240 line from my breaker box... I am gonna use a 30amp breaker and I am running an older comp, on the motor its says it draws 14amps at 240. I am gonna be using 10 gauge wiring. Is the 30 amp breaker and 10 guage wiring sufficient, the compressor is about 30ft away.
The comp is 2HP.
Also if the compressor has 3 wire plug and my house dryer has a 4 wire plug because its a new home, does that mean I will have to run a 4 wire connection when I run the new breaker?
The comp is 2HP.
