trbomax
I started doing the clean-up on the sb I picked up a few years ago.Its been sitting in the shop and today is the first I have looked at it.I knew the cast iron conduit between the starter and the switch was broken but whats inside it is puzzeling to me.It seems that there are 2 starters in line. The first one off the motor is mounted on the base. The (broken) conduit goes up to a start/stop switch. But then a bundle of wires run out of this switch and go into what I believe was the original start/stop/reverse switch,then back to this start/stop switch. Inside the old start/stop/reverse switch houseing is what looks like another motor starter. So there is now no provision for reversing the motor and two starters? What is all this?
