I'm fairly certain this can be done but I want to make sure I go about it the safest way.
I have a single 30A 220V 10Ga line going from my main panel to my detached garage (Red, Black, White, GND). I would like to have two separate 110V lines without adding another panel in the garage.
Could I replace the main panel breaker with two 20A breakers and then connect one circuit to each hot lines and share the neutral in the garage? Would I still use all 20A wire and outlets in the garage for each of the two circuits? I this correct for a multiwire branch circuit?
Any tips from electricians to keep this "code" would be great!
Thanks!
Thanks!
