mmhouse
My concrete driveway was getting very discolored and splotchy and I was having to power wash it every spring because it looked so dirty. The concrete had become very porous and was just soaking up the dirt.
I power washed the entire drive this spring and then power washed small sections again just before coating them. I first coated with Behr #880 concrete primer and after letting that dry for at least 8 hours according to instructions I put on a final coat of Behr #800 concrete 'stain.' It was a fairly time consuming process but the appearance is great so far. It now looks like brand new concrete. Hopefully this will also seal the concrete so it doesn't soak up so much crud and help protect it from further damage as well.
Before and after photos are attached.
If one of you posted that you were doing this without my having any experience with the product I probably would have told you that you were nuts. However, I've had the product on my front porch for 4-5 years and on my sidewalk for 2 years and it's held up well to both the weather and to power washing. I had also used it on a sidewalk at a previous house a number of years ago and had good luck with it there too. So I decided to give it a try on my driveway.
By the way, I don't consider this product to be a true stain. It does not appear to soak into the concrete to any significant degree but instead sits on top more like a paint as far as I can tell. I'm not certain why Behr calls it a stain. It is fairly thin so maybe that's the reason or maybe it's just for marketing reasons. That's why I put the word stain in quotes in the title. However, the bonding agent/primer appears to do a pretty good job of adhering it to the concrete surface, at least on my lightly broom finished porch, sidewalk and driveway.
So far I have driven on it without any problems (after 72 hours). The instructions say not to park on it for two weeks so I haven't tried that yet. That will obviously be the ultimate test.
I'll keep you all posted on how it holds up.
FYI...I have no affiliation with Behr.
