Starrett 18A
Larryjones
WV
I was given this in a box of junque. I know it is an automatic center punch, this one is different. It is springy when pushed but no click action.The tip is more like a pin punch. What is it for? Parts missing?
L
Larryjones
WV
Thanks for the pic Rich, mine seems to have a spring missing. I still don't know what it was used for.
Wamsutta
Amarillo, Texas
rviceli solved the mystery. Somebody installed a locating tip from an 819.
It looks like they have all the parts available for their punches. I have an 18A and I must say it's a fantastic tool. I use it for marking pre-drill holes for wood screws in 2x4's. It's faster and more accurate than using a pencil mark.
MFolks
Springfield Mo.
I've used the 18B for many years when drilling holes in metal panels. It works far better than the hammer and center punch method. Snap a starting mark in the metal & then the drill bit while using cutting oil,followed by the correct tap hole for cutting threads.
zmotorsports
Northern Utah
I use mine a LOT. If I am center punching on a scribed intersection, I simply use the snap punch which will put a small dimple, then follow it with a center punch and hammer to create a larger crater for the drill bit to rest in. For thinner materials or non-ferrous materials many times the spring punch is enough and following up with a center punch and hammer is not even necessary.
Mike.
Wamsutta
Amarillo, Texas
zmotorsports, have you tried the 18C version? That thing is a brute and packs a punch. On thicker steel, it'll put a deep crater on the mark. Only stipulation though is the spring action seems tougher than the tip. You'll have to sharpen the tip from time to time.
zmotorsports
Northern Utah
No I haven't tried that one. Maybe I'll have to.
Thanks.
Mike.
